454 code use - NCRS Discussion Boards
454 code use
  • Calvin C.
    • May 31, 2002
    • 240
    454 code use
    What build date car will this engine work for, the engine is for sale, I have a 1973 car built late 1972.
    Passinger side front TO828CWM 13S402230
    casting 3999289
    date GM10 1 H15 72
    Cal
  • Dick W.
    • 10483
    Re: 454 code use
    Need build date or last four digits of your VIN to be sure. But if usage of the 9289 block and the suffix code works for your application it sounds like it might work. The worst you could do in judging is loose the VIN points if every thing else is correct
    Dick Whittington
    • Michael W.
      • April 1, 1997
      • 4290
      Re: 454 code use
      This block was cast August 15th 1972 and was assembled August 28th, then found it's way into car S/N 2230.
      If your car was built less than 6 months after Aug 15th 1972, this block will work from an NCRS Flight point of view.
      Hope this helps.
