71 Tire Folowup Question - NCRS Discussion Boards
  • David G.
    • December 1, 2002
    • 99
    Have located a gentleman with NOS RWL Goodyear Wide Tread F70-15. I would use these for judging only. Are there date codes or anything I should look for to make sure they are correct for my car built in June 71? Judging manual refers to raised "Load Range B" and a DOT stamp. What is contained on the DOT stamp? These tires are fairly expensive and I don't want to get wrong ones. Thanks
  • Dave S.
    • August 31, 1992
    • 2925
    Re: 71 Tire Folowup Question
    David,
    Your car would need a tire with the long 11 digit alpha/numeric code. Any tire manufactured after January 1971 will have that "long" code. The last 3 numbers indicate the date of manufacture of the tire. For instance my 71 is a May 11, 1971 build. The original tires are dated(last 3 numbers) 171 for the 17th week of 1971. These tires are hard enough to find but having a tire predate the build of the car by a reasonable time period adds another complication.
    • Robert E.
      • April 1, 2004
      • 398
      David, I have what I thought was on original '71 F70-15 Speedway tire, but has an 8 digit code. It reads "B7NDLJD1". How would you decode this?
      Robert
      • Dave S.
        • August 31, 1992
        • 2925
        Robert,
        It may well be a 71 original tire. If your car was built in 1970 you would have the "short" date. There is only one person I know who can decode that tire. Hopefully he will read the post and assist you.
        • James Keddie
          I also have what I believe to be the original spare for my '70. It is a Goodyear Wide Tread Speedway F70-15 blackwall with serial or date "ATNDLJDY". Any help in decoding the date would be appreciated. Thanks.
