GM parts specs - NCRS Discussion Boards
GM parts specs
  • John M.
    • January 1, 1999
    • 1553
    GM parts specs
    Gentelmen,
    I hope you will indulge me in a little off topic post. I am looking at a GM part # 8637742, Is there any way to get the specs for this part? This is supposed to be an adapter to replace the quick-disconnect fittings on the trans cooler lines on a 4L60E trans, and replace them with flare type lines. Unfortunately, they do not specify whether the flares are SAE or AN and the do not specify whether the flare in the fitting is male or female. I can make either work, but I just need to know which fittings to buy in addition to the GM parts. I am getting real close to firing the 59 up, and just don't want to wait until the GM fittings to arrive to find out what other parts to buy.
    Regards, John McGraw
    • 43221
    Re: GM parts specs
    John------
    There is no easy way to get specs for a GM part that I know of. In a case like you have I think the easiest thing to do would be to just "reverse engineer" it from the part. In other words, try the different fittings until you get the one that works. Return the fittings you don't need.
    • John M.
      • January 1, 1999
      • 1553
      Re: GM parts specs
      Thanks Joe,
      I kind of figured as much, but was just trying to cut out some time involved.
      • John Daly
        Re: GM parts specs
        John
        That part has a 1/2-20 UNF thread on the female hex end and a 1/4-18 straight pipe thread at the other...hope this helps
        JD
