Re: 427 crankshaft - NCRS Discussion Boards
Re: 427 crankshaft
  • Mike
    Re: 427 crankshaft
    Wally -
    I've been following this thread with great interest. Over the holidays I picked up some parts in a trade, including a forged steel crank represented as coming from a '66 L72 427-425. After spending some time with my "Chevrolet By The Numbers" book, I concluded the 6223 casting number so clearly visible after I purchased the crank (and apparently invisible before that point) indicated it was from a 65-69 396. The book noted that a 396 crankshaft's third counterweight is 3/4" thick, while that of a 427 is 7/8". Mine is 3/4".
    Could this crank actually be from a 427? Could a 396 crank be safely used in a 427, in spite the lower rotating mass? Would this cause a balance problem or possibly shorten the life of the engine?
    I had planned to sell the 6223 and buy an aftermarket unit with a slightly longer stroke to increase displacement.
    Mike (33053)
  • Wally
    Re: 427 crankshaft
    I use them, no problem. Ther is a big move in the industry to make cranks lighter, the SB Nascar units are under 40 pounds and have very small and narrow rod bearings.
    If you are going in the motor anyway, balance the motor and the thinner counter weight will make no difference.
