Solid Axle Ceramic Brake Linings from MPB - NCRS Discussion Boards
  • Tom B.
    • March 1, 1978
    • 720
    Has anyone used the new ceramic brake linings from Master Power Brakes Compamy? They claim 25% better braking and are a direct replacement. The link is below.
    Tom
    High Performance Ceramic Brake Shoes
  • Mike E.
    • February 28, 1975
    • 5136
    Re: Solid Axle Ceramic Brake Linings from MPB
    I'm interested in what "high volume" wheel cylinders are. Larger bore diameter?
    If so, I'm sure you can claim more braking with larger bores. Are they properly balanced front and rear, and in conjunction with the master cylinder? GM engineers did spend a bit of time on this--I trust those guys.
    • Tom B.
      • March 1, 1978
      • 720
      I was wondering about that too Mike. The first thing that came to my mind was if it was going to require a larger capacity master cylinder.
      Tom
