'67 RADIO ANTENNA - NCRS Discussion Boards
'67 RADIO ANTENNA
  • Rob A.
    • December 1, 1991
    • 2126
    '67 RADIO ANTENNA
    The antenna components on my '67 are original, grounding plate, body, bezel, etc. When viewed from the back, the antenna is not vertical, but angles to the inside. I assume it should be vertical, and if so, is it possible I installed something incorrectly? (The antenna itself is not bent)
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: '67 RADIO ANTENNA
    IT should be vertical. Loosen things up and see if you can move the mounting components slightly. Check to see that you have it installed properly and the aluminum piece is correct.
    • Mike M.
      • May 31, 1974
      • 8388
      there is a barrel-shaped piece that slides down the shaft . its the last piece to go on before slipping the antenna mast up thru the alum. plate and body. its cut on a slight taper. rotate it till the antenna sits vertically, then tighten the spanner nut . mike
      • Rob A.
        • December 1, 1991
        • 2126
        Mike,
        I'll check it out...if you're talking about the piece that goes on the outside, on top of the rubber gasget, there's a tab on it that fits into a slot in the hole in the fiberglass, so I really can't rotate it much.
        • Mike M.
          • May 31, 1974
          • 8388
          rob: piece that os rotatable is on underside. it makes contact with the aluminum ground plate. mike
          • Rob A.
            • December 1, 1991
            • 2126
            I gotcha....thanks....
            • Rob A.
              • December 1, 1991
              • 2126
              Mike,
              Looking at the LIC catalogue, the piece you are referring to is only on '63-'66 antennas, and I don't remember there being one on mine, but I'll go under and take a look.
