C1 59: Spark plug lead clip - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12738
    Hi all,
    Just another question: which number bolt hold the clip on the oilpan to clip the two front spark plug leads ?
    thanks,
    Rob.
    The '59 engine swap
    Rob.
    NCRS Software Developer
  • Chris H.
    • April 30, 1990
    • 817
    Re: C1 59: Spark plug lead clip
    I had the same question. Heres the answer. In the end it was about the only place the wires would reach.
    "Chris, I believe that they are in the fourth bolt from the front going back. The front oil pan bolt (at the front seal)is larger (not sure of the size)than the middle bolts and that is where I started counting from. If you are counting just the small bolts than yes, it is the third from the front.
    right front oooxooooo
    left front oooxooooo"
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12738
      Re: C1 59: Spark plug lead clip Thanks! *NM*
      Rob.
