Re: the candle wax trick - NCRS Discussion Boards
  • Steve Antonucci
    This thread was quite interesting. Unfortunately, every time I snap off a
    bolt, the start of the threads are below the surface. My lot in life !
    In any event, can anyone explain ( or attempt to ) exactly what melting the
    wax does? Does it pull heat away from the bolt faster than the surrounding
    metal? I'd just like to know.
    Steve
  • Clem Z.
    • January 1, 2006
    • 9427
    i wish i knew but it does work on NTP plugs. i never tried it on just plain bolts.
    • Ronnie Robertson # 36786
      It's the wax & heat
      I was told that the heat caused the bolt to expand. WHen the wax is applied, the bolt cools and the wax is drawn into the area between the bolt and the threads - thus providing lubrication. Other lubricants tend to evaporate with the heat. Heat is necessary to disrupt the bolt/thread contact, not just melt the wax.
      Whatever the molecular reasonings, its has always worked for me. SOmetimes patience and repeated waxings are necessary.
      This trick still works when trying to ues a left hand drill bit or a easy-out.
      • Steve Antonucci
        Re: It's the wax & heat
        Ronnie,
        Thanks for the reply. It makes perfect sense. I've seen people go to town
        with the WD-40 on exhaust manifold studs like this. I will absolutely try
        this wax idea soon.
        Thanks for the reply on this.
        Steve
