71 Tire Judging - NCRS Discussion Boards
71 Tire Judging
  • David G.
    • December 1, 2002
    • 99
    71 Tire Judging
    71 currently has Firestone Firehawk 225-70R15. Considering purhase of Coker Firestone Wide Oval F70-15.Confused about point deductions for these tires.Will Coker receive 10% deduction from 30 originality pts vs. 60% deduction on Firehawks? Deduction %'s seem to differ from Judging Reference Manual to Tech Info Manual. Thanks in advance
  • Dick W.
    • 10483
    Re: 71 Tire Judging
    The deductions will be as per the 6th edition of the Judging Reference Manual. The deductions refered to in the TIM & JG are out of date.
    Dick Whittington
    • David G.
      • December 1, 2002
      • 99
      Re: 71 Tire Judging
      Can somebody tell me what deductions on these two tires will be since my 2 manuals are out of date?
        Re: 71 Tire Judging
        As I read the "white book", the Coker wide oval repros will get either a 20% or 30% deduction, depending on how closely they match the originals in terms of design, construction, tread width and pattern, and sidewall appearance. To get only a 10% deduction, they have to be EXACTLY the same as the originals except for the DOT markings.
        • Dick W.
          • 10483
          Re: 71 Tire Judging
          Unless Corkey has changed his tire, the sidewall lettering, tire construction, and tread differs quite a bit from the original
          Dick Whittington
          • William C.
            • May 31, 1975
            • 6037
            Re: 71 Tire Judging
            I believe the introduction of the Goodyear a few years ago moved the bar in terms of "acceptable" reproduction
            Bill Clupper #618
            • Dave S.
              • August 31, 1992
              • 2925
              Re: 71 Tire Judging
              A couple of years ago Kelsey made a few changes to their very good reproduction Goodyear and now makes it "right on". They are the best you can get. I know it is made in Raised White Letter but I'm not sure about white stripe. As mentioned the Firestone reproduction is not very close.
              • David G.
                • December 1, 2002
                • 99
                Re: 71 Tire Judging
                Thanks everybody. Sounds like the Goodyears from Kelsey are the way to go for the best available reproductions.
                • Gerard Q.
                  • February 1, 2000
                  • 284
                  Re: 71 Tire Judging
                  Just for reference I received a 3pt deduction at a chapter meet last year and a 10 deduction at a regional meet this year with my 71 using the Firestone F70-15 repo's.
                  • Chas Henderson #28127
                    Try this;
                    Buy some nice steel belted radials - get five of them, unless you have an original, drive to the meet, you will probably break even on the point deduction, 30 points, and enjoy the thrill of driving a great car. Thats what I do when I have my car judged. Cheaper in the long run than buying poor handling bias tires.
                    Chasman
