3970010 blocks - NCRS Discussion Boards
3970010 blocks
  • Brian J.
    • August 31, 1999
    • 70
    3970010 blocks
    Can anyone tell me if all the 3970010 blocks were cast with the same alloy, or were the earlier blocks the more desirable high nickel content?
    Brian
    Re: 3970010 blocks
    About nine million 3970010 blocks were made over its 11-year run, and the additional tin/nickel alloying is cast into the front face of the block on the blocks poured that way. There's nothing "magic" about the "010/020" blocks - they got additional tin to improve machinability (longer tool life between changes) and additional nickel for a slightly harder finish-machined bore surface. Not a "big deal".
      Re: 3970010 blocks - Addendum
      As with most things Chevrolet, this got close scrutiny from the beanies, as the additional tin and nickel added product cost at the foundry level; when the promised overall cost reduction results didn't materialize (tool savings in the engine plants and long-term bore wear resulting in reduced warranty costs) enough to be identified, the more expensive "010/020" alloying quietly disappeared.
      • Brian J.
        • August 31, 1999
        • 70
        Thanks John *NM*
