C2 - Cleaning of the Rearend Differential - NCRS Discussion Boards
  • Rory Riedy
    All,
    Has anyone had experience cleaning up the rearend differential. Can the unit be sandblasted without taking it completely apart? If so what is the best way to protect against sand infiltration into the unit. Once cleaned what is the best way to protect the new finish?
    Thanks as always.
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C2 - Cleaning of the Rearend Differential
    if they aren't too rusty, i usually go over them with a wire brush in a drill motor. if they are real bad, i usually disassemble them, inspect gears and bearings and replace as needed, then blast them empty. i've always feared some blasting media may get behind the yolks. mike
    • Rob A.
      • December 1, 1991
      • 2126
      At one time, I had the differential out of my car, removed the side and front yokes, and inserted tight fitting caps in the openings. I took it to a sand blasting shop to have it cleaned up, and like Mike said, they told me the grains would find there way in no matter how I tried to protect it, and I took it back home. The old wire brush on a high speed drill works fine. I've used krylon satin clear to retain the natural finish on many parts with good success. Not sure, but you might want to use a high-temp clear on the rear end.
