4-Speed Trans ID - NCRS Discussion Boards
4-Speed Trans ID
  • David Lyon
    4-Speed Trans ID
    I posted a similar message several months ago with no definitive ID. I have a 4-speed transmission in my '58 which I know is not correct. The top of the cover on the driver's side has 3884655 GM and a tag has 3915077. Does anyone recognize these numbers? Also, the speedometer cable attaches on the passenger side. The transmission works fine, just curious. Someday I might find the correct dated BW.
    David
    • 43232
    Re: 4-Speed Trans ID
    David-----
    Based upon the information you provided, you've got a 1968 Muncie with wide ratio. This particular transmission was originally installed either in a 1968 Corvette with non-posi rear end or a 1968 passenger car with big block engine.
    • David Lyon
      Thanks Joe! I hoped you would see my post. Now to find the correct dated BW for the car built January 10, 1958. Thanks again!
      David
