C1 horn relay #781 - NCRS Discussion Boards
C1 horn relay #781
  • Pat #25912
    C1 horn relay #781
    Judging guide says cover is gloss black but there are 2 NOS 781's on eBay right now in original "Delco Remy" boxes that the covers are cad. Were there different variations of the 781. Thanks. Pat
    • 43231
    Re: C1 horn relay #781
    Pat-----
    The covers changed in later SERVICE. I think that all the originals and earlier SERVICE parts had black covers. Later, in SERVICE, the covers changed to plated. If you have an original black cover for a non-serviceable unit, you can transfer it to the new part. If not, you can paint the cover black. If the cover is still of the generation that had the Delco-Remy embossment, it should appear pretty close to original.
    • Chris H.
      • April 30, 1990
      • 817
      Per the 61-62 JGM the horn relay was generally CAD plated however some gloss black covers may appear.
      Chris
        Depends on time frame....
        As Chris pointed out, non-painted cover is considered factory concours correct for late '61 and '62 Corvettes. The earlier JG's ('58-60) mandate covers painted black. Here's the story.
        The cover is stamped steel and was zinc plated to boot. But, early runs of the '781 had the cover dip painted in black enamel on top of the plating. Looks like GM/Delco underwent a cost reduction in the early 60's to stop wearing belts and suspenders when it came to rust prevention!
