Steering Column Adjustment - NCRS Discussion Boards
  • John L.
    • 409
    As I remember, the steering column has an adjustment whereby you could position the steering wheel closer to the dash for a larger person or further out for a smaller person. I thought the procedure was in the service manual however I cant find it. Is anyone out there familiar with the procedure.
  • John L.
    • 409
    Re: Steering Column Adjustment
    I forgot to mention -- this is for a 67
    • Stephen L.
      • May 31, 1984
      • 3158
      A telescopic steering wheel has this adjustment Option #02N36AA. A standard does not.
        • 15674
        The '63 models have this feature and the procedure is in the '63 Corvette Shop Manual, but I'm not sure if it carried through all the way to '67. I recall the total travel range is 3" and I set mine as far forward as possible.
        • Bob R.
          • June 30, 2002
          • 1595
          Re: How was this adjusted ??
          Duke, just curious on the adjustment for a 63. Is it just the distance you insert the shaft into the rag joint? I don't see anythink else that's adjustable.
          • Wayne K.
            • December 1, 1999
            • 1030
            I don't have a shop manual handy but as I recall there is a slotted bracket attached to the column that bolts go through that secure the column to the vehicle under the dash. I seems to me that if you loosen those atttaching bolts and the clamp at the rag joint the column can be moved fore and aft.
            Wayne
            • Pat #25912
              I believe there is also a clamp in the engine compartment, at the firewall where the column comes out.
                • 15674
                Yes, both the shaft and column have to be adjusted, which involves fasteners both in the engine compartment and under the IP. I would refer anyone interested in the details to the '63 Corvette Shop Manual. If the procedure is not in the CSM for your year, then it may not be applicable.
                • Rob A.
                  • December 1, 1991
                  • 2126
                  When I removed the steering column in my '67 I had marked the position of the bolts that hold the slotted bracket in place. The position of the bolts changed slightly when I reinstalled it, but I don't think it is meant for any other purpose than slight adjustments to how the body is mounted in relation to the steering box. I can see, however, that by inserting the end of the column shaft further into the rag joint, there is a small adjustment possible.
                  • William C.
                    • May 31, 1975
                    • 6037
                    I believe the fed crash standards introduced in '67 precluded the adjustment used in '63-66. The '67 is not to the best of my knowledge, adjustable unless equipped with a tele column.
                    Bill Clupper #618
                    • Mike M.
                      • May 31, 1974
                      • 8385
                      clup is correct: the only significant adjustment of a 67 column is an accident at speed as the 67 was the first year for "the crush on impact" cloumn. mike
                        The outer jacket on the '67 has two upward-lanced protrusions at the firewall clamp location, and the band of the clamp locates between these two protrusions to positively locate the column fore-aft; as Mike noted, it was NOT designed to be adjusted.
