Help with Rear End ID - NCRS Discussion Boards
  • Mike B.
    • November 1, 2004
    • 389
    Can someone provide info including gear ratio etc for the following rear end?
    Casting #3725899 F57 GM 25
    Thanks in advance.
  • William C.
    • May 31, 1975
    • 6037
    Re: Help with Rear End ID
    The gear ratio info is stamped into the bottom flange, it cannot be discerned from casting numbers. What are the stamped numbers?
    Bill Clupper #618
      That's a '57 non-posi diff, cast on June 5, 1957. The assembly date and ratio code is stamped on the front face of the passenger side of the housing; hard to see - will probably take some cleaning/wire-brushing to bring it up.
