59 Door Panel - NCRS Discussion Boards
59 Door Panel
  • John C.
    • September 30, 2001
    • 130
    59 Door Panel
    I'm in the process of removing the panel to get to the window stuff, I was able to remove the window crank but not the lock latch, and hints?
  • David Lyon
    Re: 59 Door Panel
    John,
    I believe 56- 62 all had the same door lock knob. My '58 comes off by removing the retainer clip, same as the window crank, and the knob should pull off. If it doesn't, I suspect it's corroded to the spline it's connected too on the shaft. Might take some effort to work it off. I believe the shaft and spline are the same material and configuration as the window crank shaft.
    David
    • Mike M.
      • May 31, 1974
      • 8385
      Re: 59 Door Panel
      dave's got it correct. spray a little kroll or wd 40 on shaft/knob interface, then tape knob/handle with fiberglass hammer head a few times and they usually come off. mike
