61 front wheel cylinder help needed - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2925
    I have what I believe are the correct front wheel cylinders which are numbers 821 and 822. They have a 7/16" inlet. The only reproduction rubber hoses I can find are 3/8" on the male end. Am I missing something.????
  • William C.
    • May 31, 1975
    • 6037
    Re: 61 front wheel cylinder help needed
    What is the full casting number of the cyl's you have?
    Bill Clupper #618
    • Dave S.
      • August 31, 1992
      • 2925
      Bill,
      They are 1 1/8" bore. Numbers are 5453821 and 5453822. Both have the Delco Moraine markings on them.
      • William C.
        • May 31, 1975
        • 6037
        Do you have std brakes or HD metallic? Casting for std brakes is 5459527 & 528, 1 3/16 dia all 1960-62. The '821 castings are used with the metallic brake systems The proper hose for all is 3696551, 7/16X20 external thread and 3/8X24 internal thread, 17" O/L (same as '55-57 Chevy), at least per the '65 Parts book
        Bill Clupper #618
        • Dave S.
          • August 31, 1992
          • 2925
          Bill,
          Thanks. It is a metallic brake car. Do you know if the hose is available.???? The reproduction folks don't seem to have such a hose.
          • Mike M.
            • May 31, 1974
            • 8385
            what you have are 49-50 chevy pass car wheel cylinders which have same casting # as you rpo vette BUT they take the larger brake line tubing and flare nut chevy used in 49 and 50.. you can get adaptors to allow the chev pass car cylinders BUT the judges will catch it. i bought a purpotedly orig nos wheel cyl for my 61 rpo vette several years ago from a guy in , i believe ohio. they were as you describe and as i have a 49 coupe and a 50 convert, i immediatly recognized their origin. i called the seller, informed him of their non-vettte application, returned them to him for full refund. mike
            • Dave S.
              • August 31, 1992
              • 2925
              Mike,
              Thanmks for the clarification. Who says buying parts and restoring these cars is easy. I guess I have a couple of boat anchors for my model boats.
              • Mike M.
                • May 31, 1974
                • 8385
                did ya buy them out of the drtiveline like i did? the seller refunded when educated(or caught). mike
                • Dave S.
                  • August 31, 1992
                  • 2925
                  Mike,
                  These were bought on EBAY. Seller represented them as being correct for my 61 when I asked the question prior to bidding. Obviously I didn't realize there were 2 versions of the same part and I'm sure the seller didn't either. I'll contact the seller who is an NCRS member and see what happens. Thanks again for the clarification.
                  • Dick W.
                    • 10483
                    Dave, if they are the same as 55-57 passenger car, the Raybestos number is BH381174. NAPA, Carquest, etc should be ablr to cross part number
                    Dick Whittington
