Battery Tender Question - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello Everyone:
    Ref: '66 L-72
    I have a question, should I remove (or keep the battery in place) while I have my battery connected to a battery Tender over the winter months.
    Last winter I had a repo-tartop vented type battery which I did remove because I was concerned about acid vapour being emited into the engine bay and I needed to repair the battery tray.
    This year, I have a new sealed maintenance free GM battery and I'm asking the advise of the board. Should this battery be removed, or can I safely leave it the car and just disconect the cable(s)?
    As usual, thanks for your help.
    Best regards,
    Kurt Neiman
  • Rick S.
    • January 1, 2003
    • 1203
    Re: Battery Tender Question
    Kurt, Thats what I have done for 6 yrs with my GTO and Corvette (in a heated garage) and I haven't had any problems.
    Rick
      • 15674
      You should disconnect the battery, but I see no need to remove it from the car.
      It's a PIA on SB cars since you usually have to remove the expansion tank and heater hoses.
      Another thing you can do is connect the Battery Tender to a timer and only run it for about four hours in the afternoon - the warmest part of the day.
      • R N.
        • May 31, 2002
        • 640
        Thank you Rick & Duke. *NM*
