C1 motor mount, why would somebody.... - NCRS Discussion Boards
  • Pat #25912
    cut a notch in the pass side front support? Before I fix it, I thought I should ask if there is a purpose for handiwork such as this. Do you think Bubba may have worked on my car? Thanks.
  • Mike M.
    • May 31, 1974
    • 8386
    Re: C1 motor mount, why would somebody....
    wasn't Bubba who torched the mount. his cousins, the Bar Brothers(Crow, Pry and Wreckin). mike
    • Eugene B.
      • May 31, 1988
      • 710
      Pat,
      Just a wild guess, but in the old days when the boys drag raced their hot rods, there was a procedure to by-pass the motor mount with a piece of chain that went from the engine bolt to the frame.
      The chain was kept pretty tight and it was used to keep the engine torque from trying to rotate the engine upward and pull the rubber motor mount apart.
      As I said, just an educated guess.
      Gene
      • Roy B.
        • February 1, 1975
        • 7044
        In Ca. back in the late 60's many people added OLDS, Buick and Cad engines in C1 Corvettes.
        • Ted S.
          • January 1, 1998
          • 747
          Wrong fuel pump and they need clearance for the fuel line, maybe?
