IGNITION SWITCH APPLICATION - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I have a Delco Remy ignition switch box marked GM 1116673 686Y. The switch itself, however has a casting #697 on it, which someone crossed out with a marker and wrote 686. It looks just like the one on my '67. I believe a 686 is correct for '66 and/or '67. Assuming the # on the switch itself is correct, what is its' application?
  • Joe R.
    • July 31, 1976
    • 4550
    Re: IGNITION SWITCH APPLICATION
    Rob,
    It's a genuine 1968 only ignition switch. DO NOT try it in your 66-67 application unless you want to run and smoke test and inform the rest of us how it came out.
    JR
    • Rob A.
      • December 1, 1991
      • 2126
      Thanks, I don't plan on installing it, but wanted to know its' application. I assume your information is based on the switch#, and that the box doesn't belong to it?
      • Joe R.
        • July 31, 1976
        • 4550
        yep!
