Left Turn Signal - NCRS Discussion Boards
Left Turn Signal
  • Vince Malvagna
    Left Turn Signal
    I have a 1970 Corvette, My Left turn signal just quit working, The right one works fine, I get nothing at all from the left side ( no blinker, & no lighting front or rear.) I checked the bulbs, & the fuse box, their fine. HELP.... Thanks, Vince.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: Left Turn Signal
    Sounds like the turn signal switch in the steering column is at fault. Does the left brake lite still work? Do the 4 way flashers still work?
    • Don Izzo
      If after checking all of the above your light still doesn't work, check the ground wire at the rear light which goes to a ground bolt to the frame. I found mine had broken off at the connector. A quick fix if you know where to look!
      Don
      • Wayne M.
        • March 1, 1980
        • 6414
        Result of new law passed in red states *NM*
