C1 Rear Springs - NCRS Discussion Boards
C1 Rear Springs
  • Jimmy G.
    • November 1, 1979
    • 976
    C1 Rear Springs
    I have a 1960 that needs new rear springs. I drive the poop out of the car and originality is not my primary concern. Anyone had any good luck with a particular brand of service replacement spring. I may even consider a heavy duty spring set-up with the extra pieces. I used a local spring shop on my 1958 years ago and was not 100% satisfied as the car still sat too low in the rear for me. I can't stand the C1's that look like they have air shocks either. Any comments
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C1 Rear Springs
    www.eatonsprings.com might have what you want.
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 Rear Springs
      What is wrong with air shocks?? and how do you know unless you lay on your back to see them. They will correct weak rear springs.You just add air to get the look you wont.
      I'm not criticizing you , just asking unless your going NCRS %100 and you said NO.
