Differential Casting #s - NCRS Discussion Boards
  • Larry W.
    • April 7, 2008
    • 54
    I have been all over the web and cannot find any info on my differential.
    The carrier has two numbers - C268 and 3725899. What do they mean?
    Thank you for any help.
    • 43246
    Re: Differential Casting #s
    Larry-----
    The casting number 3725899 was used for non-posi (i.e. "open") differential carrier housings for 1957-62 Corvettes and 1957-64 Chevrolet passenger cars. The "C268" is a date code and indicates a casting produced on March 26, 1958.
    • Larry W.
      • April 7, 2008
      • 54
      As I have a 58 it might be the original?
      Thank you !
        What's the ratio/date code stamped on the forward-facing passenger side of the housing? You may have to clean the rough-cast surface thoroughly in order to read it; the ratio code will help determine if it's original.
        • Larry W.
          • April 7, 2008
          • 54
          Those numbers don't exactly jump out at you. It appears to be - 4A402 or AA402.
            Larry -
            "402" is April 2nd, and makes sense with the March 26th casting date. However, no "AA" ratio code was ever listed as used on a C1 diff; codes for '58 were AE, AH, AN, AP, AQ, and AS, AT and AU - the last three were only used with RPO 684. If it's really "AA", it may be a passenger car diff - I don't have those ratio charts.
            • Larry W.
              • April 7, 2008
              • 54
              Thanks again. I'll check more closely and see if I can get a better read.
              • Verne Frantz
                John, Larry,
                AA shows up as '58 Passenger with 3.55 ratio & 3-spd trans.
                Verne
