C1 - Horns - NCRS Discussion Boards
C1 - Horns
  • Jimmy Johnson
    C1 - Horns
    How can I tell if my horns are working properly and have the correct sound on my 1959? Jimmy
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 - Horns
    Jimmy...
    The right is a low note (F) p/n 441 and the left is a high note (A) p/n 442
    • Brad K.
      • August 31, 1990
      • 414
      Re: C1 - Horns
      The latest 58-60 Judging manual (4th edition) lists the horns as follows:
      "Left and right Delco Remy horns are solenoid type with a near triangular shaped bell. Right hand horn is low note; left hand is high note. Horns are painted gloss black and carry the following part number ID. RH "351"; LH "352". Horns are mounted with the bells facing forward, tipped down slightly. When viewed through the grill, only the bottom part of each bell is visible"
      Rebuilding horns is a tricky business. If your horns sound muffled or if they won't make any sound at all when you test them, then there is a high probability that they need to be rebuilt. 40 years is long time and most horns have had internal moisture and rusted-through diaphrams or else the points will will have rusted together. You CAN rebuild them yourself....but it's tough to get a clear and correct sound. You have to "tune" them. Your simplest bet is to HAVE them rebuilt. Start with Hornworks at www.classiccarhorns.com
      Good luck!
      • Mike E.
        • February 28, 1975
        • 5138
        Re: C1 - Horns
        441 and 442 horns are 61-62 only, and have a different shaped bell than the earlier ones.
        • Dennis A.
          • April 30, 1999
          • 1010
          Re: C1 - Horns
          Mike...
          You are correct, I over was thinking '61...
