LS1 block drains - NCRS Discussion Boards
LS1 block drains
    • 15601
    LS1 block drains
    Looks like there are two:
    Large brass plug on drivers side, just above the pan rail, between the front of the case and the mount. This one takes a 17mm hex.
    A smaller brass plug on the passenger side directly above the starter.
    Has anyone removed the large one, and is it really a coolant drain for the case?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: LS1 block drains
    sounds like you found them according to the shop manual. pass side towards the rear and driver side towards the front of the block
      • 15601
      Thanks for the confirmation Clem, now to find a 17mm hex tool. It doesn't seem worth the trouble to drop the starter to drain the cylinder case.
      • Christopher R.
        • March 31, 1975
        • 1599
        17mm hex is a common size used on foreign cars. Believe VW and Audi use that today for oil pan drain plugs.
        • Chas Kingston
          Just an RCH smaller than 11/16"
          Geezer
            • 15601
            I found 17mm hex drive socket at Snap-on on-line store, also 17mm stock for the drive bit -- so I do have a source if nothing more economical becomes available. The hole is not a full hex, so I want to have the proper size tool so as not to damage the brass plug.
            I really was looking for some assurance that the large (about 1.5 inch diameter) brass plug on the driver's side toward the front is really a coolant drain. From the F-body FSM it looks like this is also the location for the block heater, so that may account for the large size.
              • 15601
              This large brass plug is indeed one of the LS1 cylinder case drains, and takes a 17mm hex to remove. The other is above the starter and takes a 5/16 hex according to reports. I elected not to remove the one above the starter.
