Distributor mounting 327 vs 350 - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    Will the distributor off my 68 327 properly mate up with the internals and block in the 77 350 I'm rebuilding?
    If it will, I plan to re-build it accordingly. If not I'll keep it in the 327.
    Chuck
    Re: Distributor mounting 327 vs 350
    Yes, it'll bolt right in - no difference.
    • Mike McKown
      The distributor will fit the new engine fine. It's your car it's not compatible with. I believe your '77 used HEI ignition and electronic tach. If it did, you will have to rig your wiring for coil resistance in the ignition circuit and a lead to pick up the tach signal.
      HEI's are cheap and work well.
      • Chuck R.
        • April 30, 1999
        • 1434
        The 350 is dropping into my 68 coupe John, I guess I should have been a little more accurate in my explanation.
        Typical misleading Chuckster question. Sorry about that John.
        Chuck
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Whoops ..... See how I am Mike?
          John, Mike, potato potaato Sorry Dude!
          I have a bare 69 tach drive housing that I was looking to totally rebuild, but after checking into the quantity and COST of rebuild components, I think I'll just freshen up my working 68 tach and call it good.
          Thanks to you BOTH getting back to me so quickly.
          Chuck
