Identifying a block and heads - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5153
    I just brought home a stray 62 fuelie with a wrong 350 motor next to it. I'm having trouble identifying what I have.
    The block is a common 3970010---casting date is E244 stamped is V0528 TMD
    Truck motor?
    The heads are (I believe) 3988997 (wish that they were 57 997 heads!!!!!)
    Casting dates are F1872 and F1472.
    The dates are easily deciphered, of course, but what were the original installations? PAss car, truck, etc?
    Mike Ernst
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Identifying a block and heads
    all TMDs are truck engines
    • William C.
      • May 31, 1975
      • 6037
      '74 Chevy Truck Mike.
      Bill Clupper #618
        • May 31, 1974
        • 8411
        i'll bet its the 74 silverado bill c put a 62 vette body on. you can probably make a killing if you can find the owner of the 74 silverado cab and reunite him with his engine. good luck rev and regards. mike mc, still sleeping at the foot of the cross as you directed at the last confessional.
        • Tracy C.
          • July 31, 2003
          • 2739
          Well you just better be careful there Mikie...
          When an honry critter like yourself sleeps that close, sometimes the "cross bar" will fall off an conk yer head.
          pleasant dreams...
          tc
          • David D.
            • April 1, 1990
            • 330
            Mike, According to Hollander, the TMD is a 350 4BC 160hp out of a 1974 Chevy or GMC Truck, 20 & 30 series. FWIW, more than likely it is a 4 bolt main block, for that application. Dave
