Wiring Harness & Breakerless Ignition - NCRS Discussion Boards
  • Lawrence Berte
    This is a two part subject. First, has anyone any input on wiring harnesses from Lectric Limited, Eagle Wire Products, or M&H Electric Fabricators. Input such as quality, availability, but most important, original appearance . Now on to the second issue, I've read many posts concerning a replacement ignition triggering system to replace the stock points setup. If you want a simple (1) wire conversion that looks totally OEM, operates by (hall-effect) has protection circuit which shuts system off if ignition is left on, and can also be installed without removing the distributor. Check it out at www.breakerless.com , let me know if you have tried it, or just what you think about it. They have a very informative sight.
    Thanks, Lawrence Berte
  • Gary S.
    • July 31, 1992
    • 1632
    Re: Wiring Harness & Breakerless Ignition
    I know that I have read fairly good things about the Pertronix unit but I like this one better because of the single wire. Looking to hear some input on this. Gary
    • Bob Lanham
      How hard is it to put in a wiring harness? *NM*
