72 Speedo question - NCRS Discussion Boards
72 Speedo question
  • Bill Lloyd #33481
    72 Speedo question
    My speedometer is oscillating between 50 and 70 mph at a constant 55 mph. Is this an indication of certain cable failure or is the speedo at end of life? I have never seen this one before. The cable usually snaps and the speedo stops.
  • Gary S.
    • July 31, 1992
    • 1632
    Re: 72 Speedo question
    Bill, I had a similar problem in my 66 and all I did was to pull the speedo cable out and clean the tube and relube. It was a LOT easier getting to it than the one on my 72. Often an erratic speedo is indicative of a bent cable or one that is binding. Gary 21316
    • Robert C.
      • December 1, 1993
      • 1153
      Bill , speedometer "bounce is a common ailment. It is usually the cable or the little plastic wheel piece in the transmission side of the cable. Lube the cable first.
      • Bill Lloyd #33481
        Thanks. I will pull it out and lube it up.
