what is the method of removal on these clips?, if you want to save them. and/or which vendor sells the proper clips? Thank you in advance; David
65 brake line clips (to frame)
Re: 65 brake line clips (to frame)
David -
If you mean the green clips with the hollow tubular rivet in the middle, it's tough to remove them without damaging them; they were originally installed in the hole in the frame when the rivet was straight (not expanded), then a "burp gun" with a pointed/tapered shank was used to expand the rivet inside the frame to retain them. Paragon has replacements - about eight bucks each.- Top
