Fan clutch rebuilders - NCRS Discussion Boards
  • Jim Baxter
    Anyone know of fan clutch rebuilders? I am trying the keep the 327/350 car as original as possible.
  • Jeffrey S.
    • August 31, 2000
    • 33
    Re: Fan clutch rebuilders
    Jim,
    I have heard that Vintage Automotive Research does a good job. You can reach them at (954)755-1161.
    Jeff
    • Eugene B.
      • May 31, 1988
      • 710
      Jim,
      Another option is Fred Oliva. He advertises in the Driveline. Page 15 in the Sept-Oct issue.
      Gene
      • Jim T.
        • March 1, 1993
        • 5351
        You can contact Fred Oliva at foliva@gate.net for fan clutch rebuilding. He add for this service and flasher capacitors, chrome plating, zinc plating, and compartment plug kits is in the NCRS Driveline.
        • Jack H.
          • April 1, 1990
          • 9906
          Fred Oliva = Vintage Automotive Research *NM*
          • Jim Baxter
            Re: Fred Oliva = Vintage Automotive Research
            Fred at vintage said $169 and 4 to 6 months. Thanks for the replies
              The GM replacement (P/N 3916141) is still available, and is almost identical to the original.
              • Bill Stephenson
                --------Back in 1998/9 I had my original done over by Fred and while it looks good and scores perfectly it does nowhere near as good a job pulling air as a new GM replacement. Therefore it has become a high-point show piece that hangs on the wall. I have no problem with Fred as he is a nice guy, but the redone in my case just doesnt compare............Bill S
                • Jim Baxter
                  Fred said the original fully engages at about 180 degrees and the after market ones engage at about 210 hence the car starts running hot. Has anyone replaced theirs with the GM replacement and does it work fine?
                  • Jim Baxter
                    Is this original
                    Here is my original, I thought it had never been changed. Is it correct for a 65 327/350?
                      • September 30, 1999
                      • 710
                      Jim, Fred did mine and it works fine also scores perfect. Mike
                      • Craig S.
                        • June 30, 1997
                        • 2471
                        Re: Is this original
                        Jim - this looks like a correct Scwitzer bar type clutch.....Craig
