C2 65-66 Clutch Cross Shaft Differences - NCRS Discussion Boards
  • John L.
    • 409
    Is there really any difference between the 65-66 big block and small block clutch cross shafts. Long Island and other parts houses call for separate cross shafts however they look an awful lot alike. From what I have gathered from others, they are both 11 inches long.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: C2 65-66 Clutch Cross Shaft Differences
    John -- There MUST be some differences, however minor. Otherwise there wouldn't be 3 different X-shaft GM part #'s. [3832857 '63-'66 1st design, exc. 396,427] [3872962 '65-66 396, 427, 1st design] [3888279 '66-67 2nd design].
    After a quick glance at both my '65 327 and 396, it appears the differences are only in the angle of the arms welded to the tube; early 327 shafts that use the longer lever-to-clutch fork rod have a lower lever that is about 30 degrees forward of a vertical opposed upper (clutch pedal rod) lever, whereas the BB and later SB's have a lower lever that is only about 15 degrees forward. Think the later change is for clearance of the BB exhaust manifold flange, as well as other mechancial moment/force advantages.
      • 43221
      John and Wayne----
      The difference in the angular relationships between the lever arms is the only difference between the cross shafts.
