C-1 59 Block - NCRS Discussion Boards
C-1 59 Block
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 59 Block
    Found a 519 block with no numbers on the stamp pad. Casting date D159. I have not seen this block and the man could not tell if it was D 15 9 or D 1 59. Any way to tell a Flint block from a Tonawanda block? Thanks in advance
  • William C.
    • May 31, 1975
    • 6037
    Re: C-1 59 Block
    Just as you posted, a "59 for the year would be a Tonawanda Block, a "9" for the year would be a Flint casting. In the 327 engines, there is also a difference in the orientation of the casting date. It runs parallel to the crank centerline, rather than perpendicular to it. Likely the same applies to a 283 also, others may have firsthand info...
    Bill Clupper #618
      Re: C-1 59 Block
      All Flint small-blocks have a 1/8" NPT hole with a square-head pipe plug in it right behind the timing cover bolt at the 11 o'clock position as viewed from the front; Tonawanda blocks don't have that hole.
