Mid Year Spare Tire Bolts - NCRS Discussion Boards
  • Clark D.
    • August 31, 2004
    • 50
    I need to repair the thread inserts where the spare tire carrier bolts screw into the frame. Since I don't have the bolts yet, can someone tell me the size and thread of what the female insert should be. Thanks
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Mid Year Spare Tire Bolts
    Clark:
    There are no inserts. The bolts are threaded directly into the frame. I believe that the bolts are 1/4" - 28 NF.
    Joe
    • Clark D.
      • August 31, 2004
      • 50
      I am sorry for any confusion, the bolts you reference must be for the tub. I was refering to the 9in bolts on the V brace.
      • Rob A.
        • December 1, 1991
        • 2126
        The bolts originally were held in place with weld nuts inside the frame. If they have rusted away I don't think they can be replaced, but you can reach in and hold a nut in place to hold the long bolts that hold the spare tire brace. It's not easy, but you can do it. Use a lock washer under the nut so it catches and holds the nut as you tighten the bolts. I don't know of any other option if the weld nuts are no longer there.
        • Bob R.
          • June 30, 2002
          • 1595
          I believe the bolts are 3/8" coarse thread
            Another prime application for Riv-nuts (but 3/8"-16, not 5/16"-18); see my post up a couple of threads under "63 Fasteners".
