C3 1972 Tilt Column Key Warning Switch - NCRS Discussion Boards
  • THOMAS WILSON
    Im looking for a C3 1972 Tilt Column Key Warning Switch . I can't find a listing in the catalogs I have. If you look in the 1972 Service Manual under STEERING 9-22 the part is #13 Key Warning Switch. Let me know if you know where to find one .
    • April 30, 2003
    • 104
    Re: C3 1972 Tilt Column Key Warning Switch
    I purchased this switch in late August from Dr. Rebuild. Item # 2187411 fits the tilt/tele column.
    Mike
    • Gary S.
      • July 31, 1992
      • 1632
      Thomas, if you have access to the past Restorers, there is a short article in there that I wrote concerning the switch. The tilt/tele switch is no longer available from GM but the non-tilt switch is. I was able to find one from (foggy on the name of the company) a company with a name something like COrvette Steering. I will check my records on that but they advertise in the Driveline. There are also numerous dealers in used and salvage parts that may be able to help you out.
      Gary Schisler
      72 LT1
      • David H.
        • December 1, 1996
        • 241
        Thomas; e-mail me for info on a switch Doggy165@yahoo.com David
