67 Vin Tag Area - NCRS Discussion Boards
67 Vin Tag Area
  • Jeffrey S.
    • August 31, 2000
    • 33
    67 Vin Tag Area
    On my 67 Coupe, under the glove box where the VIN and Trim Tag are located, the bar that those tags are connected to has some yellowish-green paint showing. Is this something from the factory or perhaps a sign that my car was repainted yellow at some time? Any help with this is appreciated.
    Jeff
  • Brandon K.
    • April 1, 1997
    • 474
    Re: 67 Vin Tag Area
    You're not talking about the green primer are you? (sortof an olive green color)
    • Jeffrey S.
      • August 31, 2000
      • 33
      Re: 67 Vin Tag Area
      yes I gues you caould call it olive green now that I look at it again. Would the primer be in that area? looks like it has black there too (olive green) is on the bottom of bar, black is in the front where the tags are. I am ignorant when it comes to 67's and noticed this when I was looking at the VIN tag. I just recently bought this 67 and have spent too much time with "Sharks" where a lot of things are different.
      Thanks Brandon!
      Jeff
      • William V.
        • December 1, 1988
        • 399
        Re: 67 Vin Tag Area
        The olive yellow primer was applied at the factory. I think it zinc-chromate.
        • Jeffrey S.
          • August 31, 2000
          • 33
          Re: 67 Vin Tag Area
          Then they painted the underdash frame black? THe reason for my question is that it looks like the primer is on the bottom of that frame bar but the front where the VIN tag islocated is painted black.
          Jeff
          • Brandon K.
            • April 1, 1997
            • 474
            Re: 67 Vin Tag Area
            I have seen original, unrestored cars that had both black paint and the green primer on different areas of that bar. I'm not sure what the order of operations was, or the reasons for the various paints. It doesnt sound like yours was from a sloppy repaint job though.
            Brandon
            • Stephen L.
              • May 31, 1984
              • 3158
              Re: 67 Vin Tag Area
              The cage assy, of which the vintag mounting bar is a part, is zinc chromate (olive color) painted. You should also see that paint color in the cage areas above the frame under the doors. The bar was painted black in the vintag area during the blackout process of the car, to "dress up" that area as it shows when seated in the passenger seat.
              • Jeffrey S.
                • August 31, 2000
                • 33
                Re: 67 Vin Tag Area
                Thanks guys....sounds like mine is as it should be.
                Jeff
                • Mike Cobine
                  Re: 67 Vin Tag Area - Paint and primer
                  Here are some photos of the frame bare of the dash.
                  • Ralph E.
                    • February 1, 2002
                    • 905
                    Mike,
                    Can't see the VIN and Trim tags in the pictures. If you removed them, how will you re-install? Looking at the pix was that a car blue?
                    • Mike Cobine
                      It is an eBay picture. You find lots of things to buy there, including cars with no VINs and Trim tags.
                      From the pictures, I'd say it was blue once. From where it is, I'd say "from the pictures" it appears that may be the original color.
                      66 conv project - not mine
                      • Jeffrey S.
                        • August 31, 2000
                        • 33
                        Mike,
                        Thanks for the excellent visual. That is very close to how mine looks. Of course mine has the VIN and Trim tags attached!!
                        Jeff
