67 427/435 Oil Pan - NCRS Discussion Boards
67 427/435 Oil Pan
  • Donald W.
    • August 12, 2013
    • 190
    67 427/435 Oil Pan
    Have made 2 attempts to stop the pan gaskets from leaking, with no success. Lot's of engine gearheads out there with comments i'm sure, so tell what i'm doing wrong.
    Thanks for your help,
    Don
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67 427/435 Oil Pan
    check to see if fel pro make a 1 piece pan gasket for the BBC like they do for the SBC. make sure all the bolt holes on the pan rails are flat,if not hold the pan rail flange over the edge of a work bench and use a hammer to make sure all the bolt hole are flat
      • 43205
      Don and clem-----
      Fel-Pro #OS-30061T
      • Donald W.
        • August 12, 2013
        • 190
        Thanks Joe *NM*
