Need help establishing price for L/88 crank - NCRS Discussion Boards
  • Steve Antonucci
    Hello everyone,
    I ran into a guy two weeks ago who offered me an original L/88 crankshaft
    ( part number 7115 ) along with some other SHP goodies. I only need to
    establish a fair price for the crank and offer it to him. This crank is
    NOS ( cross-drilled & tufftrided ) and I'd like to get it. Can any of you
    give me an idea of the price of a new one from GM ( assuming they are still
    available )? If not currently available, what was the last "known" price for
    one? And the important question, how much should I offer for it? In other
    words, how high should I expect to go for it in case the seller wants more.
    Steve
  • Dick W.
    • 10483
    Re: Need help establishing price for L/88 crank
    I believe that if you search the archives you will find that Howards Cams had "7115" cranks for sale at a deep discounted price. I believe that is was under $200. I do not know if they have any left but it would be worth checking out. Probably cheaper than yer buddy
    Good Luck
    Dick #8806
    Dick Whittington
      • 43221
      Dick and Steve-----
      I think that all of the cranks available from Howards are "3856223" forgings, although they, apparantly, have them both nitrided and non-nitrided. Actually, the 3856223 forging may have been used on some L-88s, especially SERVICE engine assemblies. The "7115" forging was last available from GM under GM #3967811, but it was discontinued in February, 2000. At the time of its discontinuation it carried a GM list price of $695.00.
      If the crank you are speaking of is NEW, it might be worth the above price, but for that money you'd be close to the price of some aftermarket cranks that are likely better. Rather than pay $695 for this GM crank, I'd spend another $200-300 and get a top quality aftermarket piece.
      If the crank is used, it's not worth anything like $700.
      • Steve Antonucci
        Dick,
        Thanks for the pointer towards Howards Cams. I just called them - NG on the
        '7115 crank! They never had any is the story I got. Only '6223 cranks.
        So, my price questions are still out there. Any input?
        Steve
        • Steve Antonucci
          Joe,
          You beat me to the quick on the Howards Cams '6223 crank issue. No surprise
          there! So then let me ask you this question. If I build an L/88 engine with
          an aftermarket crankshaft ( non-'7115 ), will this be a negitive factor in the
          value of the engine? L/88's mean Corvette anyway, so the point is moot beyond
          this realm.
          I often bounce back-and-forth on the engine internal originality issues.
          Obviously, new pistons & cams get applied all the time. But what about the
          crankshaft and rods? Do many of the members here put in top of the line
          aftermarket rods & cranks as well? Just wondering?
          Lastly, what crankshaft would you recommend as a "better than" replacement for
          the infamous '7115 crank?
          Steve
          • Clem Z.
            • January 1, 2006
            • 9427
            flatlander racing has 3967811 listed on their web for $821
            • Steve Antonucci
              Clem,
              Do you have a ontact number or name @ Flatlander I can talk to?
              Steve
              • Steve Antonucci
                Clem,
                I found them. I'm there, but I don't see the crank you mentioned listed.
                Did I miss something?
                Steve
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  i went to google and typed in "3967811 crankshaft" and it came up
                  • William C.
                    • May 31, 1975
                    • 6037
                    I think the search for 7811 crank is a waste of money, if not time unless endurance racing is actually your goal, and then, as Joe has mentioned, a better aftermarket solution is available, so what is the point of spending premium dollars for 35 year old tachnology?
                    Bill Clupper #618
                    • Mark #28455
                      Lately, I've been rebuilding my motors with the Eagle 4.25 stroke internally balanced crank available in 4130 and 4340 for $600 and $700. Since it's internally balanced, all the 427 flywheels, harmonic damper etc can be used and it can't be identified on an assembled motor. It will also gain about 50 ft/lbs torque.
                      • Steve Antonucci
                        ... so what is the point of spending premium dollars for 35 year old tachnology?
                        Bill,
                        A fair question. That's why I asked my questions in the first place. I wasn't
                        sure the '7115 crank was worth the probably $800.00+ the seller will ask for it.
                        Since many members here are quite knowledgable about this stuff, I thought I
                        would defer to the "more experienced" big block guru's.
                        Steve
                        • Scott Marzahl
                          Steve,
                          Have you investigated SCAT crankshafts? They are pretty competively priced and nice pieces. If you want the best, give Velasco cranks a call. They have built a few for me and they are the best. When you walk in the door, the cranks waiting to be picked up are tagged with the who's who in racing.
                          • Mike M.
                            • May 31, 1974
                            • 8386
                            a buddy bought up 18 of the howard cranks. non nitride were 99 with free shipping . he got the nitride ones for 135 with free shipping also. i got one of each for the same prices. they aren't gm products. appear to be overseas based on the cardboard boses they came in. mike
                            • Steve Antonucci
                              Hi Mike,
                              Run that by me again please!
                              The '6223 cranks available from Howards Cams are overseas products? Are they
                              liscensed by GM? Are they the same forging quality as the GM '6223 cranks?
                              This is the first time I heard this. I talked to Howards Cams today and they
                              told me that they bought approx. 5,000 of these cranks from GM. What's wrong
                              with this picture? Is GM out sourcing the cranks?
                              Steve
