60 big brake shoe substitution - NCRS Discussion Boards
  • Larry Boden
    hello all,
    Does anyone recall the GM make or model of the brake shoes that fit a big brake drum. The standard shoe for a 60 is quite a bit smaller than the drum should use. If memory serves me correctly, it was an Oldsmobile shoe that did the job. But, I can't recall the year or model. Any assistance would be appreciated. Larry Boden
    • 43207
    Re: 60 big brake shoe substitution
    Larry-----
    Yes, it is Oldsmobile. My recollection is that it's a late 50s-early 60s application.
    • Dave S.
      • August 31, 1992
      • 2924
      Larry,
      57 Oldsmobile front shoes are the correct 2 1/2" wide X 11" drum and should fit perfectly.
      • Mike M.
        • May 31, 1974
        • 8379
        Dave is right on. i have 57 olds shoes on the front of my 61 big braker. mike
        • Larry Boden
          thanks for the heads up on the fronts. My guess is the rears must be the same do to lack of response. (I haven't checked them) Am I right? Thanks again
          Larry
          • Dave S.
            • August 31, 1992
            • 2924
            Larry,
            The rears are different. I believe the #684 and #687 cars use the same shoes and they 1 3/4" wide.
            • Dave S.
              • August 31, 1992
              • 2924
              Larry,
              Rear shoes for a 51-58 Chevrolet Bel Air or 68-71 IHC Scout will work. They are 1 3/4" wide and fit an 11" drum.
              • Tom P.
                • April 1, 1980
                • 1814
                56-64 Olds for front
                2in (same as std front brakes) for the rear.
                O'Reillys and NAPA carry them. The NAPA number is TS160, and they are stocked in the Dallas, TX warehouse. That is what I have on my home made HD brakes on my 56. I just called my local NAPA friend and he confirmed that they are available in Dallas (probably also in other NAPA warehouses in the country).
                The O'Reilly number is 160 and the Okla City warehouse has 5 sets. My cost on the O'Reilly shoes is $21.95. I keep 2 sets of fronts under the workbench for my 56 (you never know when these sort of things will become discontinued). I don't know exactly what the lining material is made of, but they appear to be of a partial metalic composition.
