Any recommendations on the best way to reattach an armrest on a 1978. Both sides have pulled loose but I was able to fix the drivers side, at least temporarily, with the metal sleeve that is sold by most of the supply houses. I tried the same thing on the passenger side but the plastic insert that was originally at the end of the armrest has split and it will not hold.
Should I try to glue the plastic guide back together and use the aftermarket metal sleeve or is there a better and more permanent way to fix it?
