10.5 or 11 inch clutch in my 60 Vette - NCRS Discussion Boards
  • Dave #34924
    If I am replacing pressure plate, clutch disc, and throw out bearing and still using the stock flywheel, can I go to a 11 inch setup with NO problem.
    • 43221
    Re: 10.5 or 11 inch clutch in my 60 Vette
    Dave-----
    I've heard different things on this, but I now think that the 11" pressure plate will fit within a 57-62 Corvette bellhousing. However, although the 57-62 flywheel is a 14" flywheel, it is not drilled and tapped to accept an 11" clutch pressure plate assembly. In my opinion, the holes would be hard to add. These are a special configuration hole (unthreaded counterbore preceding threads) and, most importantly, the holes have to be absolutely precision drilled as to location.
    • Robert Willis
      You have to use the flywheel for the big clutch . The 57s had the large wheel but were drilled for the small clutch. I'm not sure if the C-1s ever had the 11 inch clutch. I have used the 11 inch clutch and flywheel in the old cast iron bellhousings.
      Bob
      • Terry B.
        • December 1, 1988
        • 111
        I don't know what the part number is on my 60's flywheel but I do have a 11 inch clutch with the aluminum housing. The 11 inch clutch was listed as a taxi usage at Napa when I last checked.
