C1 Rear Axle Assy. - NCRS Discussion Boards
C1 Rear Axle Assy.
  • Larry W.
    • April 7, 2008
    • 54
    C1 Rear Axle Assy.
    I recently bought a 58 project. As I crawled under to examine it more closely I found that the rear end housing is a 60 - 62 positraction - I am not sure about the center section though. Anyway my question is - Is there any value in the differential housing and should I offer it for trade/sale or should I just refurbish everything as is.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Rear Axle Assy.
    Just use it as it is , why bother changing it ? also you have the posi bearings" heavy "
    • Larry W.
      • April 7, 2008
      • 54
      Thanks! I assume you mean the axle bearings.
      • Don H.
        • December 1, 1981
        • 1484
        If you plan to have the car judged, you could possibly loose points. If you plan to drive and enjoy the car, leave it alone. Don H.
        • Roy B.
          • February 1, 1975
          • 7044
          Yes the axles ! The pumpkin will have a large "P" if it's a Posi. You could cut the brackets off the banjo to look more like a 58 banjo but people that know could still tell by looking at the banjo ends to see the bearing housing reversed for the larger bearings.
