65, 66 & 67 4 Speed Shifters - NCRS Discussion Boards
  • Mark S. Lovejoy
    When did the General change from transmission mount to frame mount shifter linkages?
    Mark
    • 43221
    Re: 65, 66 & 67 4 Speed Shifters
    Mark-----
    The change occured during earlier 1966. Early 1966s still used the transmission mount; later 1966 and thereafter used the frame bracket mounted.
    • Mark S. Lovejoy
      Thanks Joe *NM*
      • Gary Wilkerson
        Mark,
        My 66 #110505 built approx. Jan 7 has the shifter mounted to the tranny. Hope this helps
        Gary
        • Bill S.
          • August 31, 1999
          • 104
          Re: 66 & 67 4 Speed Shifters -- quieter?
          I have a early 66 and have a shifter rattle that will not go away after many attempts to quieten it. Will the frame mount eliminate this very annoying buzz at speeds avove 55 and when the engine is pulling???
          thanks
          Bill
          • Michael H.
            • January 29, 2008
            • 7477
            Mark,
            I have a GM Technical Service Bulletin that states "All Corvettes produced after 3-21-66 will have the crossmember mounted shifter.
            • Michael H.
              • January 29, 2008
              • 7477
              Re: 66 Shifter TSB *NM*
                • 43221
                Bill-----
                Yes, the frame mounted shifter will go a long way towards reducing the annoying noise you're experiencing. Plus, you can retrofit the frame mount to any 64-66 not originally so-equipped. The linkage is the same. All you need to acquire is the shifter bracket which is GM-discontinued but available in reproduction.
                If I ever purchased a 64 or 65 Corvette, one of the first things that I would do would be to add the frame-mounted bracket. The VERY first thing I would do, of course, would be to remove side exhaust if the car had that. But, right after that, I'd add the shifter mounting bracket.
                Some folks think that the transmission-mounted shifter provides a more positive shift. To some degree that's true. However, I haven't thrown a speed shift or power shift since 1969 and I don't intend to in the future, either. The quiet provided by the frame mount is, in my opinion, WAY more important. WAY, WAY more important. Every C-2/C-3 Corvette since mid-1966 has had the frame-mounted shifter.
                • Craig S.
                  • June 30, 1997
                  • 2471
                  So Joe - was that power shift on your 69 vette? Craig
                  • Craig S.
                    • June 30, 1997
                    • 2471
                    Re: 66 Shifter TSB
                    Mike - very interesting!! So my 66 427/425, Vin 16721, which currently has a Hurst 4 speed shifter, but I have a correct GM shifter, AND bracket.......apparently shouldn't based on your note since it was produced on March 16, 1966. I think I will install it as Joe suggests though.......for the comfort of the quiet operation ....... Craig
                      • 43221
                      Craig-----
                      No, it was in my 1968 Chevelle SS 396 L-78/M-22. I did it for the benefit of some of my cousins in the LA area. These guys were "gearheads" that used to love to see me powershift. They lived near the Pomona drag strip and used to race there. To this day, whenever I see them they always bring up how I used to powershift and how they never saw anyone do it the way I could. After I sold that car, though, I never threw a powershift again.
                      • Craig S.
                        • June 30, 1997
                        • 2471
                        Memories
                        • Jim T.
                          • March 1, 1993
                          • 5351
                          Re: 66 Shifter TSB
                          Michael thanks for sharing the information about the shifter location. A co-worker just mentioned today that he was going to look for original shifter for a 66 to replace the Hurst shifter.
                          • Craig S.
                            • June 30, 1997
                            • 2471
                            Re: 66 Shifter TSB
                            Jim - vette products of Michigan makes a great repop.....Craig
