Squeakies- Anyone try Ru-Glide? (62-340) - NCRS Discussion Boards
  • Rob Edwards
    I had an old family friend in town last weekend, he used to have a '66 SB. Drove him around in the '62, which squeaks over each and every bump. He suggested something called Ru-Glide for the body mounts and suspension bushings (which are all repro, new rubber pieces). Googling leads to threads on old Model-T forums about using it to lube the beads when mounting tires. I called Napa and the smallest container is a gallon, but costs $12. Anyone have any idea A) what the stuff is and B) whether it's good/safe for quieting down rubber squeaks?
  • Bill Jackson
    Re: Squeakies- Anyone try Ru-Glide? (62-340)
    Used it many years ago at a service (remember them?) station. Used a spray bottle to soak suspension bushings. Very sloppy but worked great. Kept them quiet for a year.
      • 15601
      We use it at school for mounting tires. It is important to lubricate the tire beads when mounting them. That stuff works for that purpose.
      • Roy B.
        • February 1, 1975
        • 7044
        Wait! you added new body mounts ( rubber) ? They are tighten down ( front,.rear.and cab area) how can they squeak?
        Are you sure it's not the rear springs or front? Or A arms? Or seats? Or????
        • Jerry G.
          • April 1, 1985
          • 1022
          Re: You may have urethane bushings( squeak) *NM*
