1978 Casting Numbers - NCRS Discussion Boards
  • James A.
    • January 1, 2001
    • 1
    I just purchased a 1978 corvette. It has a small block 350 L-48 engine. The casting numbers on the engine block read as follows: V0727CUT 18S437500 Can anybody tell me what these numbers mean
    • 43221
    Re: 1978 Casting Numbers
    James-----
    The "V0727CUT" is the engine production code. It decodes to an engine produced at the Flint, MI V-8 engine plant on the 27 of July. Judging by the VIN derivative (see below) I'd say that the year of production was 1978. The "CUT" suffix code denotes an L-48 350 with automatic transmission.
    The "18S437500" is the VIN derivative. This decodes to the 37,500th 1978 model vehicle built at the St. Louis assembly plant. The last 8 characters of this coding should match the last 8 characters of your VIN number found on the driver's side windshield pillar.
    • Ron De Vries
      V is for flint 07 is the month july 27 is day 27th cut is 350 cid 185 hp auto trans you wrote a 1 it is an L as for the rest check your VIN on the drivers side a piller about 3 inches from the bottem it it shoud read 1Z87L8S437500 if you have the original block in your car odds are you do as it is a 78 suffix(CUT)code.
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        "Casting Numbers" and date are on the rear of...
        the block, between the heads and the bell haousing.
