63 Emergency Brake Dash Light - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    Was this an option or was it standard. Also, is it a flashing light?
  • Grant M.
    • August 31, 1995
    • 448
    Re: 63 Emergency Brake Dash Light
    It was standard equipment. The bulb has a bi-metallic strip inside that breaks contact with heat and causes the flashing. The 'lights' bulb beside the brake warning light is identical. Replacement bulbs are available from several of the common parts suppliers, but I've only seen them as part of complete bulb 'kits'.
    • Timothy B.
      • April 30, 1983
      • 5183
      George,
      The bulb works exactly as Grant says, and the GE bulb # is 257.
        Still available from NAPA.... *NM*
