C2 clutch cross shaft - NCRS Discussion Boards
  • Jeremy Hedges
    I have a 65 that I am having trouble adjusting the clutch. I am wondering how to tell if the clutch cross shaft (Z-Bar) and the fork rod are the right one for the car. I believe that the 66 and later models are different, how do I tell them apart?
    Jeremy Hedges
    Re: C2 clutch cross shaft
    Jeremy -
    The P&A 30B shows:
    '63-'66 SB - 3832857
    '65-'66 BB - 3872962
    '67-'74 All - 3888279
    Don't know the specific differences.
      • 43219
      John and Jeremy------
      The differences between the 3 cross shafts involves a slight difference in the angular relationships between the lever arms as welded to the shaft. Since the difference is slight, they are very hard to tell apart without having known-originals to compare to. Unfortunately, GM never stamped a part number on these shafts and there is no other identifying number to be found.
      The fork push rods are easy to identify, though. The 64-66 small block rod is 10-9/16" long and the 65-66 big block rod and 67 and later for all applications is 8-37/64" long.
