1970 Fuel Pump problem? - NCRS Discussion Boards
  • Chris Dransfield
    My 70 big block has started to consistently bog down under hard accelleration. It runs fine at cruising speed and idles fine. I thought perhaps it might be condensation in the tank but this tested negative with the water identification paste as mentioned in previous posts. The fuel filter was also just replaced.
    I am now thinking of replacing the fuel pump. Is this perhaps a typical indication the fuel pump is going bad. The car also cranks for 6-7 seconds before starting after sitting for a day.There is some visible small rust particles in the tank from age.
    Plugs changed and timing set with no difference.
    Comments welcome.....
  • Richard W.
    • May 31, 1988
    • 58
    Re: 1970 Fuel Pump problem?
    The fuel filter isn't in backwards is it? I have experienced this before (not by me!) and it causes these symptoms. Rick
    Rick Weltzin
    • Chris Dransfield
      No fuel filter is in ok. Is there a way to check fuel pressure under heavy acceleration? Hate to spend $125 on correct NCRS fuel pump to find out it is not the problem.
      • Zachary K.
        • March 1, 1986
        • 162
        Chris, how old are the rubber hoses from the tank to the line and the line to the pump. Old hoses either could be soft and get sucked closed or could be starting to dry rot and will pull air through. Just a quick and inexpensive check!! You also have a filter (sock) on the tank sending unit pickup to check also.
        1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
        1969 L71 LeMans Blue, Bright Blue Convertible
        1970 L46 Monza Red, Light Saddle Convertible - Duntov
        1976 L82 Classic White, Firethorn
        2013 LS7 Black, Ebony, Convertible
        Moved on -
        2006 LS2 Black, Ebony, Convertible
