63 Windshield Washer Pump - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    I need the rubber diaphram for the washer pump assembly. Can someone advise if these are available and if so the suppliers name and ph#?
    • 43221
    Re: 63 Windshield Washer Pump
    George-----
    You can't purchase the rubber diaphragm as a seperate part. However, you can purchase it as part of the complete valve assembly. This piece is available in most auto parts stores in the Dorman or "Help!" carded products section. Purchased this way, you get white plastic components (whether you use them or not) and the price is usually very inexpensive for the whole valve assembly kit (about 7 or 8 bucks)
    You can also purchase the valve kit from GM dealers under GM #4914357. This way you'll get black plastic components and the kit will cost you about 20 bucks, GM list. Your choice.
    • Joe C.
      • August 31, 1999
      • 4598
      George:
      Do you mean to say "bellows", which is the actual rubber piston (seal) that fits into the pump cylinder? If so, then it is available in the aftermarket. I believe that I purchased from C.C.. The check valve assembly is, as Joe said, sold as a unit complete with plastic housing.
      Joe
      • George D.
        • August 31, 2000
        • 225
        Re: Joe
        Joe,
        Yes. I'm looking for the rubber bellows that goes between the piston/spring and the plastic valve assembly.
        George
