66 327/350 - NCRS Discussion Boards
66 327/350
  • Rich Freeman
    66 327/350
    What is the correct oem spark plug for my 66 327/350 coupe. Is it AC44 & AC45?
    Rich
    • 15695
    Re: 66 327/350
    AC 44 was OE, but the slightly hotter AC 45 will have less tendency to foul in normal drving. These plugs are only available in resistor versions now, so you will be able to find R45s.
    If you want a non-resistor plug that is the same heat range as the AC 45, you can buy the NGK B4 or Denso W14-U.
    • Michael H.
      • January 29, 2008
      • 7477
      Re: 66 327/350
      Rich,
      The correct spark plug recommended by GM for most normal street driving conditions is AC44. AC45 would be recommended if the car rarely sees any highway operation. Always use the coldest plug heat range that will survive with the type of driving that you do.
